BookmarkSubscribeRSS Feed
Thomas1
Contributor
Feb 16, 2018
How to get a formula column by row sub group
Hi there,
I d like to create a formula column (sum or mean etc.) with sub groups. The sub groups should be selected by rows, for example all 5 following rows drom a data table or in general all N rows. Any ideas to solve this with row()?
Attache a file to add the formula column.
ms
Jun 23, 2011
Solution
Re: How to get a formula column by row sub group
Not sure why you see this error message. You could try updating to the latest version to see if it helps. But, you could hard code the value of n to avoid the variable in the formula if the number is constant.
Or try with Local() instead of Parameter() (which actually is what I intended in my first post).
Local({n = 5}, Col Sum(:Data, Ceiling(Row() / n)))
Jun 22, 2012
The Col Moving Average() function is what you need to use.
For your averaging the formula would be:
Col Moving Average( :Data, 1, 0, 5 )
To calculate the sum it would be
Col Moving Average( :Data, 1, 0, 5 ) * 6
Documentation on the function is found in the Scripting Index
     Help==>Scripting Index
look for Statistical Functions
Thomas1
Contributor
Feb 16, 2018
Hi Jim,
Thanks for your fast response. Actually I'm looking for column formulas for row sub groups (for example row1 1-5, row1 6-10 ..., in general row 1-n, row n+1 - 2n, row 2n+1 - 3n...), where I can apply the column formulas from JMP.
Jun 22, 2012
That is a bit confusing......could you provide a sample table?
Thomas1
Contributor
Feb 16, 2018
Attached a sample file with a new column "Sum_of_each_5_Data_rows". This shows the sum of sub groups build from every 5 rows (N=5) of the data column.
How could this be done by using any given row numbers for the subgroup to create column formulas like  Col Sum,  Col Mean, Col Min etc.
ms
Jun 23, 2011
Try using a Row() transformation as optional ByGroup argument of the "Col Stat()" functions.
For example:
Parameter({n = 5}, Col Sum(:Data, Ceiling(Row() / n)))
Thomas1
Contributor
Feb 16, 2018
Hi ms,
Thanks for your support. Your formula works great. Despite the formula delviers the approriate reuslts, the formal editor is marking n red in the formul part:
( Row() / n ) ) )
and delievers an error code. The error code is "Error: Name Unresolved: n". Are there any reasons to be concerned?
Jun 22, 2012
try
n = 5; Col Sum(:Data, Ceiling(Row() / n))
Thomas1
Contributor
Feb 16, 2018
Thanks Jim. Your formual works also. However, similar to the solution from ms I'm getting the error code from the formula editor for n "Error: Name Unresolved: n", despite the formual is working (JMP 14.0)
ms
Jun 23, 2011
Solution
