Neo
Neo
How to get Repeatability, Reproducibility and Gauge R&R Variation values for each parameter in a table post Gauge R&R analysis via JSL?
I am conducting Gauge R&R analysis for several (~100) measured parameters. My data table with parts, operatorID/Inspector and repeats has spec limits values saved into the measured parameters columns.
Interactively doing the Gauge R&R analysis process as shown at time 1.38 mins as in this video is inefficient and incontinent when the parameters are ~100.
https://community.jmp.com/t5/Statistical-Thinking-for/Conducting-a-Gauge-R-amp-R-Analysis/ta-p/27189...
I would like to automate the process and get the the Repeatability, Reproducibility and Gauge R&R Variation values in a data table.
How to do this via JSL?
When it's too good to be true, it's neither
10 REPLIES 10
Neo
Neo
Re: How to get Repeatability, Reproducibility and Gauge R&R Variation values for each parameter in a table post Gauge R&R analysis via JSL?
@jthi Thanks, This script partly does what I need to do, but needs me to press OK for each parameter's Gauge R&R analysis (I am on JMP 16.2) at the "Enter/Verify Gauge R&R specification" window. I do not want to do this for my ~100 parameters.  How to automate the Gauge R&R analysis/ the press OK step?
var = dt << Variability Chart(
	Y(:NPN1, :PNP1),
	Model("Main Effect"),
	X(:SITE)
var << "Gauge R&R Report"n(1);
Also, I do not see the JMP generated script (when the OK button is pressed) in the log otherwise I could have got a direction to proceed.
