Jackie_
Get default value of combo box without change
Is there a way to get a default value without any click?
I want to save the default value in a variable which in this case should be "one". Any Suggestion?
Here is what I tried
New Window( "Example",
	cb = Combo Box(
		{"One", "Two", "Three"},
		<<set function(function({self},
		cb << set(1, runscript(1));
		selection = cb << GetSelected();
		Print( "Selected: " || selection )));
Re: Get default value of combo box without change
I usually use initialization values at the start of script (or configuration file). Below is simple example how those could be used here
cb_vals = {"One", "Two", "Three"};
init_cb_val = "Two";
New Window("Example",
	cb = Combo Box(
		cb_vals,
		<<set function(
			Function({self},
				Print("Selected: " || selection);
		<< Set(Contains(cb_vals, init_cb_val), 1)
You can then initialize the selectors final value with same init_cb_val if you want to
mmarchandTSI
Level V
I would probably do something like this.
default = (cb << Get Items)[1];
	cb = Combo Box(
		cb_vals,
		<<set function(
			Function({self},
