PhamBao
How to get Contour Profiler lines from fit model and update into graph builder
Hi team,
Are there any one know how to get decision boundary from fit model, then update it into graph builder
Appreciates,
jszarka
Level V
Re: How to get Contour Profiler lines from fit model and update into graph builder
You may be able to right-click in the space of the Contour Profiler graph. Choose Edit -> Copy Frame Contents. Then in the Graph Builder you can right-click in the space of the Graph Builder graph. Choose Edit -> Paste Frame Contents.
This will also bring the crosshairs into the Graph Builder. You can remove the crosshairs in Contour Profiler by right-clicking again in the space of the Contour Profiler graph. Choose Customize, then one of the options is for the Custom graph. You can change the Line Width from 1 to 0 and it will not appear.
PhamBao
Thank a lot. It works
