  • JMP will suspend normal business operations for our Winter Holiday beginning on Wednesday, December 24, 2025, at 5:00 p.m. ET (2:00 p.m. ET for JMP Accounts Receivable).
    Regular business hours will resume at 9:00 a.m. EST on Friday, January 2, 2026.
AT
AT
How to freeze control chart display when data is updated
I have a script that read a csv file and does control chart. I like to automate this process so new data is updated, the control chart does not generate new charts. I like to only see on chart with updated data.
Here is the script I used. I appreciate your help. Thanks
dt =Open(
"/Users/adatorab/Documents/JMP/PASS.csv",invisible);
obj = dt <<
Control Chart Builder(
Variables( Y( :A ) ),
Chart(
Position( 1 ),
Points(
Statistic(
"Individual"
Limits(
Sigma(
"Moving Range"
Chart(
Position( 2 ),
Points(
Statistic(
"Moving Range"
Limits(
Sigma(
"Moving Range"
obj << ShowWindow(0);
nw = New Window("Control Chart");
nw << Append(( H List Box( (obj << Report) << Clone Box)));
ih
Super User (Alumni) ih
Re: How to freeze control chart display when data is updated
I copied Bryon's control chart code into yours, added a random 'min' time, and here is what I see:
//Open a window to show a control chart and then update
//the chart every 15 seconds
//Includes a button to refresh early.
//Define variables here that need to keep their values through subsequent function calls
//This includes the window and data table
//Open a window to hold the chart (note this only happens once)
nw = New Window( "Control Chart",
	V List Box(
		Button Box( "New Data", UpdateData() ),
		holder = H List Box();
//Make a variable to hold a reference to the data table
dt = .;
//A function that will update the chart
UpdateData = Function( {},
	//Close the table if it is already open
	Try( dt << Close Window );
	//Open data table
	dt = Open( "$SAMPLE_DATA/Abrasion.jmp", Private );
	//Make the control chart
	obj = dt << Control Chart(
		Group Size( 1 ),
		KSigma( 3 ),
		Chart Col( :Abrasion, Individual Measurement ),
			Dispatch(
				{"Individual Measurement of Abrasion"},
				"1",
				ScaleBox,
				{Min( nrows() - Floor( Random Uniform( 10, 25 ) ) ), Max( nrows() + 2 ), Inc( 5 ),
				Minor Ticks( 1 )}
	//Hide the temporary control chart window
	obj << ShowWindow( 0 );
	//Remove existing/old graph from the window (if there is one)
	Try( (holder << Child) << Delete );
	//Add the new graph
	holder << Append( (H List Box( (obj << Report) << Clone Box )) );
	//Close the temporary control chart
	obj << Close Window;
//Script to update then chart and then call itself 15 seconds later
quickieScript = Expr(
	//Load the chart in the window (run the script in the function)
	UpdateData();
	//Run this same script in 5 seconds
	Schedule( 5, quickieScript );
//Start things off:
quickieScript;
12 REPLIES 12
ih
I may be going in the wrong direction here but I think you want the chart in your window to be replaced when new data shows up rather than adding another below/after it.  To do that, delete the old chart before appending a new one.  Here is an example:
names default to here( 1 );
//Open sample data
dt = Open("$SAMPLE_DATA/Abrasion.jmp");
//A variable used to hide part of the data
lastrow = 10;
//Hide data after the last row (simulates a smaller table)
df = dt << Data Filter(
	Location( {696, 15} ),
	Mode( Select( 0 ), Show( 1 ), Include( 1 ) ),
	Add Filter(
		columns( Transform Column( "Row", Formula( Row() ) ) ),
		Where(
			Transform Column( "Row", Formula( Row() ) ) <= lastrow
UpdateData = function( {},
	//Add one row to the data table
	lastrow++;
	//Update the data filter (simulates getting more data)
	df << Delete All;
	df << Add Filter(
		Where(
	obj = dt << Control Chart Builder(
		Variables( Y( :Abrasion ) ),
		Chart(
			Position( 1 ),
			Points( Statistic( "Individual" ) ),
			Limits( Sigma( "Moving Range" ) )
		Chart(
			Position( 2 ),
			Points( Statistic( "Moving Range" ) ),
	//Add the new graph
	holder << Append(( H List Box( (obj << Report) << Clone Box)));
//Open a window to show the new control chart and a button to refresh the chart
//Includes a button to run the script above.
nw = New Window("Control Chart",
	V List Box(
		Button Box("New Data", UpdateData() ),
//Load the first chart in the window (run the script in the function)
UpdateData();
AT
AT
Thanks. I use window scheduler to run this script and like to see one chart when data is read after (say 15 sec or so). I get many "control chart"). I tried your example and I put it the window task (also  Schedule function) and I get many "control chart" 1, 2, 3,.. Is there anyway you one can get only on chart?
Below is what I use. Thanks
Chart(
Position( 1 ),
Chart(
Position( 2 ),
//Add the new graph
V List Box(
UpdateData();
quickieScript;
AT
AT
Sorry I  missed first few lines. Here is the correct one.
Schedule( 15, quickieScript );
//Open sample data
Chart(
Position( 1 ),
Chart(
Position( 2 ),
//Add the new graph
V List Box(
UpdateData();
quickieScript;
ih
Now I think I understand.  The problem is that you are opening a new window every time the script runs.  At the beginning of of each update you either want to close the last window or refresh the same window with a new chart.  Below is an example of the latter.
I often write 'pseudocode' in comments before writing any real code, I find that helps make sure code actually does what I expect it to.  Then once the whole workflow makes sense I fill in the code to actually do it.
//Open a window
//Every 15 Seconds:
	//Make a chart with the latest data
	//Update the window with a new chart
	V List Box(
dt = .;
	//Open data table
		Chart(
			Position( 1 ),
		Chart(
			Position( 2 ),
	//Wait a moment to show when the chart updates
	Wait(0.2);
	//Add the new graph
	UpdateData();
	//Run this same script in 15 seconds
//Start things off:
quickieScript;
AT
AT
Thank you so much. This solved my problem.
Byron_JMP
Is the issue that you only want to see the most recent data in the conrol chart?
I've run into some scenerios where the data is being updated in some table. Each time I grab a copy of the table, I only want to see the last 50 rows, regardless of how many rows are in the table.
This is pretty easy to set up.  Just make a control chart, and adjust the x axis. Then look at the control chart script and find the part that looks like the script below.
		Dispatch(
			{"Individual Measurement of Metric 1"},
			"1",
			ScaleBox,
			{Min( nrows()-50), Max( nrows()+2 ), Inc( 5 ),
			Minor Ticks( 0 )}
Where it says Min( and Max(, edit values in the original script. Replace the number in min() with nrows()-50 and replace the number in max() with nrows()+2.
Now if you do all the fancy, delete and append stuff, you'll get a control chart with the most current data.
AT
AT
Thanks for your suggestions. I think that was my second question. Where do I insert your script in original script (above).
Byron_JMP
This is a control chart script to run against Abrasion.jmp
Control Chart(
	Group Size( 1 ),
	KSigma( 3 ),
		Dispatch(
			"1",
			ScaleBox,
			{Min( nrows()-25 ), Max( nrows()+2 ), Inc( 5 ),
			Minor Ticks( 1 )}
It uses the classic control chart platform
AT
AT
Thanks. I tried this and I get no error but I don't see x axis only twenty points.
Can you help further? I appreciate it a lot.
V List Box(
dt = .;
//Open data table
Show Two Shewhart Charts( 0 ),
Show Capability( 0 ),
Chart(
Limits( Sigma( Moving Range ) ),
//Warnings( Test 1( 1 ) )
Dispatch(
"1",
ScaleBox,
{Min( nrows()-20 ), Max( nrows()+2 ), Inc( 5 ),
Minor Ticks( 1 )}
Wait(0.2);
//Add the new graph
UpdateData();
//Start things off:
quickieScript;
