baiyun
How to freeze ColBox of TableBox via JSL while scroll X-Axis of TableBox?
I want to freeze below columns "PROGRAM_NAME_NO" and "IBType" while scrolling X-Axis of TableBox?
Is there anyone who knows how to solve this issue? Do appreciate your favor.
Re: How to freeze ColBox of TableBox via JSL while scroll X-Axis of TableBox?
Those seem to be the first two columns in the table box. Maybe following will work:
TableBoxReference << Set Locked Columns(2);
baiyun
Hi jthi,
Thanks for your answer. I have tried this solution, it does not work for me. Literally, I post my question on JMP community.
Do you have any other solutions?  Thanks
To do this interactively, go to the columns panel and right click on the column you want to freeze, and select  Scroll Lock/Unlock
baiyun
Hi txnelson,
Appreciate your answer. I've tried this solution before, it only works when you scroll the DataTable but not work while scrolling the TableBox on the window.
So I post my question here for other solutions. Looking forward to your reply!
Which JMP version are you using? I have 15.2.1 and this seems to be working:
dt = Open("$SAMPLE_DATA/Semiconductor Capability.jmp");
dt = New Window("Example",
	tb = Table Box(
		String Col Box("lotid", dt:lot_id << get as matrix),
		String Col Box("waferinlot", dt:"Wafer ID in lot ID" << get as matrix),
		Number Col Box("NPN1", dt:NPN1 << get as matrix),
		Number Col Box("PNP1", dt:PNP1 << get as matrix),
		Number Col Box("PNP2", dt:PNP2 << get as matrix),
		Number Col Box("NPN2", dt:NPN2 << get as matrix),
		Number Col Box("PNP3", dt:PNP3 << get as matrix),
		Number Col Box("IVP1", dt:IVP1 << get as matrix),
		Number Col Box("PNP4", dt:PNP4 << get as matrix),
		Number Col Box("NPN3", dt:NPN3 << get as matrix),
		Number Col Box("IVP2", dt:IVP2 << get as matrix)
tb << Set Scrollable(30, 4);
show(tb << Get Locked Columns);
tb << Set Locked Columns(2);
djhanson
I can confirm this tablebox() column freezing (like Excel freeze pane) does work in JMP 14.x but does not work in JMP 12.x.  Either way it's a great feature I'm glad JMP can do this at least in later versions.
DJ
