lukasz
How to fill values in rows till the end of an item group?
Hello everyone,
How to fill the column Param3 so that we have ones from the matching position (coming from the comparison of column Param1 and Param2) till the end of each item group (see the picture bellow)?
What I have now are only values in Param3 based on matching of Param1 and Param2. For that I use this really simple code:
For( i = 1, i <= N Rows( dt ), i++,
	If( dt:Param1[i] == dt:Param2[i],
		dt:Param3[i] = 1;
How to fill the Param3 column for further rows as shown in the first picture? I would appreciate for any suggestions.
Thank you and best regards
Georg
Re: How to fill values in rows till the end of an item group?
Perhaps this will work:
dt = New Table( "Test",
	Add Rows( 10 ),
	Compress File When Saved( 1 ),
	New Column( "item",
		Character,
		"Nominal",
		Set Values( {"item1", "item1", "item1", "item1", "item1", "item2", "item2", "item2", "item2", "item2"} )
	New Column( "Param1", Character, "Nominal", Set Values( {"", "A", "", "", "", "", "", "B", "", ""} ) ),
	New Column( "Param2", Character, "Nominal", Set Values( {"A", "A", "A", "A", "A", "B", "B", "B", "B", "B"} ) ),
	New Column( "Param3", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [., ., ., ., ., ., ., ., ., .] ) )
Wait( 3 );
group = .;
For Each Row(
	If(
		dt:Param1 == dt:Param2,
			dt:Param3 = 1;
			group = dt:Param2;,
		dt:Param2 == group, dt:param3 = 1,
Georg
Georg
	Add Rows( 10 ),
	New Column( "item",
		Character,
		"Nominal",
Wait( 3 );
group = .;
For Each Row(
	If(
			dt:Param3 = 1;
			group = dt:Param2;,
Georg
lukasz
Hi Georg,
thank you, it is working as desired
Best regards
