GCardin
How to extract only the prob > |t| from a t test report ?
Probably a very simple question but is there a simple way to extract only the prob > |t| from a t test report ? From this line which extract the full report.:
dt1 = rpt[Outline Box( "t Test" )][Table Box( 1 )];
Full script with smaller count of Xs and Ys:
// Entrer analyse et column switchers
Oneway(
	Y(:Name("553")),
	X(:Name("1")),
	t Test(1),
	Column Switcher(:Name("1"), {:Name("1"), :Name("2"), :Name("3")}),
	Column Switcher(:Name("553"), {:Name("553"), :Name("554")}));
//Report
rpt = Current Report();
colswitcher_obj = rpt[ColumnSwitcherCOntextOutlinebox( 1 )] << get scriptable object;
colswitcher_obj2 = rpt[ColumnSwitcherCOntextOutlinebox( 2 )] << get scriptable object;
colswitch_list = colswitcher_obj << get list;
colswitch_list2 = colswitcher_obj2 << get list;
// Loop column switcher 1
For(j = 1, j <= N Items(colswitch_list2), j++,
	// Loop column switcher 2
	For(k = 1, k <= N Items(colswitch_list), k++,
	// Changer le test ici
	// Concatenate table
	If(j == 1 & k == 1,
		main_tb = dt1;
		main_tb << Set Name( "All" );
		Try( main_tb << Concatenate( dt1, Append to First Table ) );
		Close( dt1, No Save );
        colSwitcher_obj << Next;
	wait(0);
colSwitcher_obj2 << Next;
wait(0);
Re: How to extract only the prob > |t| from a t test report ?
This might not be very robust method but gives one possible idea
ow = dt << Oneway(
	Y(:height),
	X(:sex),
	t Test(1),
tb = Report(ow)[OutlineBox("t Test"), Table Box(1)];
vals = tb[ColStackBox(2), NumberColBox(2)] << get;
prob = vals[1];
One pretty good option usually is to turn the table box into datatable using << Make Into Data Table and then extracting the value from that. After you have the value, remember to close the table.
ow = dt << Oneway(
	Y(:height),
	X(:sex),
	t Test(1),
dt_ttest = Report(ow)[OutlineBox("t Test"), Table Box(1)] << Make Into Data Table(Invisible(1));
val = dt_ttest[3, 6];
Close(dt_ttest, no save);
Both can be made more robust by checking where Prob > |t| is.
ow = dt << Oneway(
	Y(:height),
	X(:sex),
	t Test(1),
prob = vals[1];
ow = dt << Oneway(
	Y(:height),
	X(:sex),
	t Test(1),
