Neo
Neo
How to extract items in a list from another list with partial matches to items in a third list?
I have the following lists
bigList  = {"CD_CORN_1", "ICS_CORN_6", "IPEK21_S00R_P37_2", "CURR_S009_P37_2", "CD_CORN_2", "Ig_RF", "Cmax03_4C230RF", "NG"};
smallList1  = {"CD_CORN_", "CD_CORN_", "CD_CORN_"}; //note these are repeats and that is how I get them
smallList2  = {"IDS_CORN_", "IPEK21_S00R_", "CURR_S009_"};
smallList3  = {"RF", "IPEK21_S00R_", "CURR_S009_", "NG"};
using biglist and smalllist1, I want to get
sbigList1  = {"CD_CORN_1", "CD_CORN_2"};
using biglist and smalllist2, I want to get
sbigList2  = {"ICS_CORN_6", "IPEK21_S00R_P37_2", "CURR_S009_P37_2"};
using biglist and smalllist3, I want to get
sbigList3  = {"IPEK21_S00R_P37_2", "CURR_S009_P37_2", "Ig_RF", "Cmax03_4C230RF", "NG"};
How to do this via JSL?
(order of items in sbiglist's do not matter)
Re: How to extract items in a list from another list with partial matches to items in a third list?
I would most likely create a function for something like this
get_partial_matches = function({to_list, with_list}, {Default Local},
	/*""" Get partial matches to_list using with_list
	Args:
		from_list (list(str)): list to compare to
		to_list (list(str)): list to compare with
	Returns:
		list(str): List with partial matches in alphabetical order
	matches = Associative Array(); // associative array to avoid duplicates
	For Each({to_item}, to_list,
		For Each({with_item}, with_list,
			If(Contains(to_item, with_item),
				Insert Into(matches, to_item);
	return(matches << get keys); // << get keys to get result in a list
list1 = get_partial_matches(bigList, smallList1);
list2 = get_partial_matches(bigList, smallList2);
list3 = get_partial_matches(bigList, smallList3);
show(list1, list2, list3);
other option would be something like this, but I would much rather use the earlier one
get_partial_matches2 = function({to_list, with_list}, {Default Local},
	pattern = Concat Items(with_list, "|");
		res = Regex(to_item, pattern);
		If(!IsMissing(res),
list1 = get_partial_matches2(bigList, smallList1);
list2 = get_partial_matches2(bigList, smallList2);
list3 = get_partial_matches2(bigList, smallList3);
Here is how I would do it
Names default to here(1);
smallList1  = {"CD_CORN_"}; //note these are repeats and that is how I get them
foundList = {};
For Each( {theList}, bigList,
	For Each( {sublist}, smallList1,
		if(contains(theList,sublist),
			insert into(foundlist, theList)
	For Each( {sublist}, smallList2,
	For Each( {sublist}, smallList3,
Each separate element of bigList has to be evaluated separately.
	Args:
	Returns:
		If(!IsMissing(res),
