hcarr01
RunProgram context closed - SMTP
Bonjour à tous,
À partir d’un serveur SMTP, j’essaye d’envoyer des pièces jointes à différentes personnes.
Le script fonctionne correctement.
Le seul problème est que lorsque je rajoute « !// » au début de mon script pour qu’il s’exécute directement, j’obtiens l’erreur suivante :
Voici le script que j’utilise :
// modifier le type de codage dans le PowerShell (windows)
stringCommand = "$OutputEncoding = [System.Text.Encoding]::UTF8";
// paramètres du mail à envoyer
commands = {
	"Send-MailMessage -From '... -To '...' -Subject 'test' -Body 'test' -SmtpServer... -Attachment 'test...'",
	"exit\!n"
// script exécution PowerShell
icommand = 0;
RP = Run Program(
	Executable( "PowerShell.exe", stringCommand, ShowWindow("Hide") ),
	ReadFunction( Function( {this}, Write( this << Read ) ) ),
	WriteFunction(
		Function( {this},
			icommand++;
			If( icommand <= N Items( commands ),
				this << Write( commands[icommand] );
				this << WriteEOF;
Merci de votre aide !
Craige_Hales
Re: SMTP
see https://community.jmp.com/t5/Discussions/Bug-or-Feature/m-p/673679#M86115 .
When it works, you have a script window open the entire time. When it fails, no window is open, and JMP is using a temporary eval context which goes away at the end of the script.
You could probably also work around the issue with a loop at the end of the script that waits for the runprogram to finish before allowing the script to finish. That won't work if you expect to run other JSL or platforms while runprogram works in the background, but approximately like this:
RP=runprogram(...);
while(1,
 // check the message names, there might be another one you need too
 if(RP<<canread == 0 & RP<<canwrite == 0 , break() );
 wait(0.1);
That way the eval context will persist until runprogram is done.
Craige
Craige_Hales
Re: SMTP
RP=runprogram(...);
while(1,
 wait(0.1);
Craige
