NoScoped
How to examine VIF in a generalized regression report?
Hi there,
I'm trying to check for collinearity and want to examine the VIF in my zero-inflated negative binomial regression. How would I go about doing that? I found online that I should context click the parameter estimates and add VIF as a metric. How do I context click?
Thank you.
cwillden
Re: How to examine VIF in a generalized regression report?
Hi @NoScoped,
I think that just means to right-click.  I don't have JMP Pro, so I can't verify that you can do this in with the Generalized Regression personality, but I know this works in an standard least squares report.  You just right-click anywhere in the Parameter Estimates table and select Columns > VIF.
VIFs are completely independent of the response variable, so even if that doesn't work in the Generalized Regression report, you can always use a dummy response with a standard least squares personality and get the VIFs.
-- Cameron Willden
cwillden
Hi @NoScoped,
-- Cameron Willden
