Tomer9w
How to edit panel box components (lables)
Hi
In a script I wrote, I'm using a panel box showing two X-axis options which are long strings.
Is there an efficient way to change the display name for more convenience?
Code below is an example.
X_list hold all string representing column names I wish to present to the X axis.
Then, using panelbox to show user options.
Finally, plotting bivariate of user's choice.
I asked for help regarding X axis label, but it is best to get tips for y-axis labels too.
Thanks!
x_list = {"item1","item2"};
panelbox("x-axis", xRadio = radio box(x_list,updatePlot()));
Bivariate( Y( y_list[yRadio<<get] ),
		X( x_list[xRadio<<get] ), ...)
pmroz
Re: How to edit panel box components (lables)
Here's an approach that will give you some ideas.
dt = open("$sample_data\Car Physical Data.jmp");
x_list = dt << get column names(numeric, "string");
y_list = x_list;
updateplot = expr(
	dt << Bivariate( Y( eval(ycol) ), X( eval(xcol) ));
nw = new window("Choose",
	panelbox("x-axis",
			xcol = x_list[xradio << get];
			ycol = y_list[yradio << get];
			updateplot;),
	panelbox("y-axis",
		yRadio = radio box(y_list,
			updateplot;),
	button box("OK", nw << close window),
