Matthaneeya
How to do the Capability analysis with SHASH distribution model?
Re: How to do the Capability analysis with SHASH distribution model?
@Matthaneeya  - you can get capability analysis with a SHASH distribution in the the Distribution platform.  As long as you have the spec limits in the column(s) of interest.
Go to Analyze > Distribution, select your column(s) of interest and run the analysis.  If you have your spec limits in the column properties you will get capability analysis along with the distribution stats.  From here go to the red hot spot by the column name in the distribution scroll down to Continuous Fit and select SHASH.  You should then get a fitted SHASH distribution along with the capability analysis and Quantile Sigma Cp, CpK....  If you want to fit multiple columns at once make sure to hold down the Ctrl key and then go the red hot spot and make your SHASH distributions selections from continuous fit.
Hope this helps.
Matthaneeya
I followed your instruction and get fitted SHASH distribution but when select Capability analysis , there is no "SHASH" at the drop down list to select. Please see the picture below.
What version of JMP are you running?  SHASH distribution Capability Analysis was added in JMP 14.
Matthaneeya
My version is 14.1.0 .
@Matthaneeya
From you attached image it does not look like you have your specification limits as part of your column properties.  This is an important step in getting capability analysis results.  The reason I am guessing you do not have your spec limits in column properties is that an initial capability analysis should have shown up with the distribution if the spec limits were in the column properties.
Right click on the column header for length(or any column of interest) and go to Column Properties > Spec Limits and enter your spec limits for the measurement of interest.  You will need to do this for any data you want to run capability analysis on.
Bill
Matthaneeya
Thank you for the recoomendation, I can do the capability analysis now.
