terapin
JSL Summarize Command Creates 2 lists, one that behaves "normally", the other not.
Hi Folks,
The code below creates a data table and then creates two lists in the Summarize command, one for the By variable (date_list) and one for the Max variable (data_list).  The date_list is fully accessible using standard List commands (see code at bottom), but the data_list isn't a list as far as Is List (data_list) is concerned.  In addition, I can't count the number of items in the list, nor Show the location of a specific value in the data_list.  Is this normal behavior for a list or am I missing something subtle here about lists?  Any help would be appreciated.  Thanks
Clear Log();
dt1 = New Table( "Test",
  Add Rows( 20 ),
  New Column( "Date",
  Numeric,
  Continuous,
  Format( "m/d/y h:m", 10 ),
  Input Format( "m/d/y h:m" ),
  Set Values(
  [1767245800, 1771173900, 1805155800, 1809197400, 1843086800, 1838161000, 1889049900, 1893293200,
  1896320800, 1900281600, 1950766400, 1955499200, 1957751200, 1964247600, 1990396800, 1995976400,
  2023788000, 2029549600, 2051488600, 2056959000]
  New Column( "Data",
  Numeric,
  Continuous,
  Format( "Best", 12 ),
  Set Values( [34, 45, ., 56, 99, 67, 12, 78, 53, 89, 77, 90, ., 12, 73, 23, 12, 34, 6, 45] )
  New Column( "Year", Numeric, Continuous, Format( "Best", 12 ), Formula( Year( :Date ) ), Lock( 1 ) ),
  New Column( "Hour", Numeric, Continuous, Format( "Best", 12 ), Formula( Hour( :Date ) ), Lock( 1 ) )
Wait( 2 );
// Get the highest growth for each day
Summarize( date_list = by( :Date ), data_list = Max( :Data ) );
Is List( date_list );
N Items ( date_list );
Show( Loc( date_list, "03/15/1961 12:10 AM" ));
Is List( data_list );
N Items ( data_list );
Show( Loc( data_list, 45 ));
ms
Super User (Alumni) ms
Re: JSL Summarize Command Creates 2 lists, one that behaves "normally", the other not.
It's only the by() result of summarize that is a list. The numerical output is typically a matrix (i.e. a vector). Use matrix commands or convert the matrix to a list.
Compare these alternatives:
Is Matrix( data_list );
N Row( data_list );
Show( Loc( data_list == 45 ));
Is List( data_list = As List( data_list ) );
N Items( data_list );
Show( Loc( data_list, 45 ) );
ms
N Row( data_list );
terapin
Ah, as usual, the devil is in the details.  Thanks for the description and alternatives.  That helped me understand the difference between a list and matrix a lot better.
