I am not sure my DOE is good. I want to compare two different cell culture platforms.
I have two different culture platforms and each plat form has different ranges of rpm and working volume.
For examples, platforms A & B (categorical)
For A, 100 rpm - 200 rpm / 100mL
For B, 300 rpm - 400 rpm / 25mL
Initially, I had two factors like rpm1 (100 - 200 rpm) and rpm2 (300 - 400 rpm). Then, in 'model' I had RSM and removed irrelevant factors like rpm1*rpm2, rpm1*rpm1, and rpm2*rpm2. But I couldn't remove platform*rpm1 or platform*rpm2. I think in this case JMP will do DOE for both platforms with two different rpm , A* rpm(100rpm - 400rpm).
Is there any ways I can do DOE properly? I wonder if I can make rpm1 dependent variable to the platform A.
