  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
statlover
How to determine optimal cluster size in Hierarchical Clustering?
Which report helps us to determine the optimal cluster size from the hierarchical cluster. I have 1 to 20 clusters from the dendogram. But I am not not how to choose the right number of clusters.
Re: How to determine optimal cluster size in Hierarchical Clustering?
I assume that you already studied the documentation for the hierarchical clustering (Help > Books > Multivariate Methods > Hierarchical Clustering) that explains the various kinds of information to select a model and assess and interpret the selected model. Which information are you asking about?
statlover
statlover
Thanks. I read about the plot between number of clusters and distance. That explains what I was looking for.Thank you
