How to determine a column has formula?
I would like to remove all formulas from all columns with script. I wrote a forloop but whether a column has formula needs to be determined. How to do that with scripts?
Re: How to determine a column has formula?
One option is to use <<Get Formula with Is Empty()
col1 = dt << New Column("Ratio", Numeric, Continuous);
col1 << Formula(:height / :weight);
wait(1);
For Each({col_name}, dt << Get Column Names("String"),
	col = Column(dt, col_name);
	If(!Is Empty(col << get formula),
		Column(dt, col_name) << Delete Formula
Scripting Index has a lot of information and you can find it directly from JMP's menu Help / Scripting Index
If you add those formulas yourself and don't really need them for formula usage, you can avoid adding them all together by using << Set Each Value()
wait(1);
It worked!
Thank you so much!
