Fruit325
How to delete columns where all the rows are "NA"?
Hi I want to get some advice for data filtering. Thanks!
I have some columns where all the rows are "NA". How could I identify those columns and delete them?
The blank cells are resulted from splitting the table. Thanks!
Re: How to delete columns where all the rows are "NA"?
There are many ways of doing this (especially when scripting), below is one fairly simple script
dt = New Table("Untitled",
	Add Rows(7),
	Compress File When Saved(1),
	New Column("Column 1", Numeric, "Continuous", Format("Best", 12), Set Values([1, 1, 2, 3, 4, ., .])),
	New Column("Column 2", Numeric, "Continuous", Format("Best", 12), Set Values([., 2, ., 2, ., ., 5])),
	New Column("Column 3", Numeric, "Continuous", Format("Best", 12), Set Values([., ., ., ., ., ., .])),
	New Column("Column 4", Numeric, "Continuous", Format("Best", 12), Set Values([., ., ., ., ., ., .])),
	New Column("Column 5", Numeric, "Continuous", Format("Best", 12), Set Values([., ., ., ., ., ., 5]))
wait(1); // for demo purposes
For Each({colname}, dt << Get Column Names("String"),
	If(Col Number(Column(dt, colname)) == 0,
		dt << Delete Columns(colname);
You can also use Columns Viewer (in JMP earlier than 18) to select the columns and then delete them
In JMP18 you have access to columns manager which might be able to do something similar (I cannot test it as I was kicked out and I don't have access to my email currently to re-verify...)
Are those values "NA" or missing ("" or .)?
Fruit325
Hi @jthi
It is missing.
	Add Rows(7),
Fruit325
Hi Jarmo,
Thank you so much! It worked!
Laptop was still on so could access the email, you can perform the column selection from Columns Manager. You can even sort by the N Missing to make it even easier to select the "top" rows
I also have few addins which can do this BUT I'm not sure if they are still functional in JMP18, Analyse Columns and Delete Missing Value Columns (github.com) .
