lala
Level IX
How to delete all files in a folder?
A folder contains no folders but multiple files.
How can I delete these files using JSL?
Because this folder is occupied by other levels, cannot be achieved by deleting the folder.
rd1=Delete Directory(dir);rc1=Create Directory(dir);
Re: How to delete all files in a folder?
If you want to just delete the files, here is a modification on @jthi code to do that
dir_path = "$TEMP\test\";
If( !Directory Exists( dir_path ),
	Create Directory( dir_path );
	new_file = Save Text File(
		dir_path || "DeleteMe.txt",
		"The quick brown fox"
		dir_path || "DeleteMe2.txt",
Wait( 1 );
// Get the files in the folder
the_Files = Files In Directory( dir_path );
For Each( {file}, the_files, rc = Delete File( dir_path || file ) );
Show( Files In Directory( dir_path ) );
For me the directory gets deleted even if it has files. Maybe some of your files are still being used?
If(!Directory Exists(dir_path),
	Create Directory(dir_path);
	new_file = Save Text File(dir_path || "DeleteMe.txt", "The quick brown fox");
	new_file = Save Text File(dir_path || "DeleteMe2.txt", "The quick brown fox");
wait(1);
Show(Directory Exists(dir_path));
Show(Files In Directory(dir_path));
Show(File Exists(new_file));
Delete Directory(dir_path);
wait(1);
Wait( 1 );
lala
Level IX
I can't use Windows 7 anymore.
Be sure to use JMP 16.
Powerful For Each()
