Jackie_
How to create column formula using a column name from a list
I want to create a new column in the 2nd JMP table with a formula that simply sums the Columns contain in the list (in the code I've assigned column name to binss.
For Ex: The list contains Column names "39","41","43". I want to create a new Column in the Soft Bin Summary table with addition of all these in the formula
I can't figure out what I'm doing wrong in going from the list {""} of columns to the reference to the columns.
Any help is much appreciated.
Here's the code that I've tried
Clear Globals();
dt = Data Table( "Untitled 910" );
dt2 = Data Table( "Soft Bin Summary" );
Try( For Each Row( :Yield SummaryBins = Word( 1, :Yield SummaryBins, "[]" ) ) );
grouplist = dt:Yield SummaryBins << get values;
For( i = N Items( grouplist ), i >= 1, i--,
	If( grouplist[i] == "",
		Remove From( grouplist, i, 1 ),
binss = {}; /// list contaiting bin value
For( i = 1, i <= N Items( grouplist ), i++,
	If( Contains( grouplist[i], " " ),
		Insert Into( binss, grouplist[i] )
adad = Words( binss[1], " " );
F = Eval Expr( Sum( Expr( adad ) ) );
/// Something doesn't seem to right in the below loop
For( i = 1, i <= N Items( binss ), i++,
dt2 << New Column( binss[i], "Numeric", "Continuous", Format( "Percent", 12, 2 ), Formula( Name Expr( F ) ) ););
Thanks,
Jack
10 REPLIES 10
Re: How to create column formula using a column name from a list
dt = Data Table( "Condition table" );
Current Data Table( dt );
// Rule: Create a new Summary Column for each row in the Condition Table
// that has a value in the Yield SummaryLabel column
For( i = 1, i <= N Rows( dt ), i++,
	If( dt:Yield SummaryLabel[i] != "",
		theString = "";
		k = 1;
		While( Word( k, dt:Yield SummaryBins[i], "[] " ) != "",
			theString = theString || ", :\!"" || Word(
				k,
			) || "\!"n";
			k++;
		theString = Substr( theString, 1 );
		Eval(
			Parse(
				"dt2<<new column(\!"" || dt:Yield SummaryLabel[i] ||
				"\!", formula(sum(" || theString ||
				")),Format( \!"Percent\!", 7, 2 ));"
The only compensation that Community members get for helping other members, is the satisfaction that comes from the members they have helped becoming more self-sufficient.  Cutting and pasting of someone else's working code is not a good way to become self-sufficient.
