NaiveJaguar366
How to create banner
I'm trying to create a company banner at the top of my html output file, which is saved from a journal.
I using the following jsl code:
<jsl>
logo = open("company_logo.png", png);
logo << set size({93, 48});
H List Box(
Picture Box(logo),
Text Box( "Company Name " )
<jsl>
The problem I got is the text inside the Text Box is aligned to the top of the image. I need to get the text sitting at the bottom of the image.
What would be the best way to go about creating a nice report header.
Note: using JMP 16.
Jasean
Re: How to create banner
HListBox has an optional parameter to adjust the horizontal alignment of the child boxes.  Try
H List Box(
	Align("Bottom"),
	Picture Box(logo),
Jasean
H List Box(
	Align("Bottom"),
	Picture Box(logo),
If you want something like this
A JMP report in the right side of a display tree. The left side is a vertical stack of two items.A JMP report in the right side of a display tree. The left side is a vertical stack of two items.
You could use something like this
dt = Open( "$sample_data/big class.jmp" );
the_report = V List Box( // use vlist for capturing, not displaying
    dt << Bivariate( Y( :weight ), X( :height ), Fit Line )
logo = Icon Box( "JMPLogo" ) << getpicture; // 262 wide by 152 tall
logo << set size( {93, 48} );
New Window( "test the logo",
    Border Box( Left( 10 ), top( 10 ),
        H List Box(
            V List Box(
                Picture Box( logo ),
            Border Box( Left( 5 ), the_report )
 Using a vlistbox for capturing the report will work better than most other boxes in some rare cases. The report notices it is being created inside of the vlist and does not open its own window. I added a little space with left(5) inside the logo boiler plate, and moved the logo away from the edge with left(10), top(10).
You don't have to show the window on the screen and manually capture the picture. You could use this:
logoreport =
        H List Box(
            V List Box(
logoreport<<savepicture("f:/test the logo.png");
open("f:/test the logo.png");
To get
Saved without opening a window.Saved without opening a window.
NaiveJaguar366
Thanks for taking the time to reply. I never though about putting an Icon Box inside a Picture Box.
Many thanks.
You're welcome! I was just grabbing the picture from the icon to follow your example. It could have used the icon directly, but then I would not have been able to size it.
