ckronig
How to create an application with a data filter in the launch module?
I'm trying to create an application to produce reports based on user input. I have some experience with writing scripting, but am getting stuck and I haven't used Applications before.
I have tried to modify one of the example Applications that come with JMP, but none of these have a data filter in the launch module and what I have tried to do isn't working.
Does anyone have an example of a simple application with a data filter in the launch module that can be used as a starting point? I should then be able to modify that to do what I need to do...
10 REPLIES 10
ckronig
Re: How to create an application with a data filter in the launch module?
I have just realised that my text is truncated. For example one of the text strings is 341 characters, with spaces. The whole text string is in the table, so I assume it does not go over the bytes limit.
When I try to display the whole text string in a distribution or contingency table, even though the text is wrapped it doesn't display in full. It appears to be truncated. Any tips?
