UserID16644
How to create a loop and add column in subset tables and add value based on specific column value?
Hi all, I have a table subset
I have two questions.
1. How can create a loop that adds column "Ref" to every subset table?
2. Also, is it possible that the value of the created column will be based on the highest number of N Rows with a specific value?
For example, the new column to be added will be Ref. Column Ref's value will be based on Column Country, wherein it should add 1 to the highest N Rows Value of America only.
CountryN Rows Ref
Argentina4
America0
America51
Brazil2
Brazil4
Canada2
TIA
Re: How to add column in subset tables and add value based on specific column value?
Here is an example of one way to do the looping.  The real issue is how to get the list of tables to loop across.  This example assumes that
     Tables=>Subset
with a Subset By was used
names default to here(1);
dt =
// Open Data Table: Big Class.jmp
// → Data Table( "Big Class" )
dtSubsetList = dt << Subset(
	By( :sex ),
	All rows,
	Selected columns only( 0 ),
	columns( :name, :age, :height, :weight )
for each( {table}, dtSubsetList,
	table << new column( "Ref");
	wait(0);
	table:ref[table << get rows where( :age == col max(:age))]=1;
I am not sure what your definition of as "column subset" is.  Is what you are referring to, the data tables created from
     Tables=>Subset
when  Subset By is checked
and a separate table for each level of the variable(s) selected is made?
UserID16644
After I have subset the table, how can I create a loop to add a column "Ref" on all the subsetted tables?
*Will rephrase the question
     Tables=>Subset
dt =
	By( :sex ),
	All rows,
	wait(0);
UserID16644
What if my data looks like this? The column Country is in character type, how can I get its highest N Rows? Assuming that I am getting the highest N Rows from America. From the example you have given, I think it is in numeric data type
CountryN Rows Ref
Argentina4
America0
America51
Brazil2
Brazil4
Canada2
I assume something similar to this will be what you need
table:ref[table << get rows where( :Country == "America" & :N Rows == col max(:N Rows, :Country))]=1;
I suggest you take the time to read the Scripting Guide, to learn JSL.  If you are not familiar with programming and at least one programming language, I suggest you search the internet for a free course on "Learn how to Program".
