How to create a formula column to find the maximum of several columns
Feb 3, 2014 05:00 PM(26800 views)
I have several columns of numeric data (see example below) and I would like to create a formula column to find the maximum value for each row across the columns. Any help would be appreciated. Thank you!
Value 1 Value 2 Value 3 Max Value (I would put the formula in this column)
