Mcc99
How to create a fold change heat map?
I'm having some difficulty figuring out how to create a fold change heat map in JMP pro. I have five samples, with various concentrations of almost 300 compounds. I would like to visualize the data via a heat map like the example below, with each sample above, each compound ID on the side, and the continuous color scale determined via the fold change. The heat map function in Graph Builder doesn't seem to take multiple compounds at once, and the cell plot only does the values. Is this type of graph called something else in JMP? Or is there something wrong with my set up?
Re: How to create a fold change heat map?
Try using a Cell Plot
     Graph=>Cell Plot
Each column in the graph is a column from the data table, and the labeling also comes from a separate column
Mcc99
From my understanding cell plot does the color scale based on count. Is there a way to specify fold change instead?
The cell plot uses whatever value is in the cell for the specified column.  So if the cell value has the fold change value, that is what will be used in the graph.
I'm not sure how your data is formatted so I assume your data has few rows and lots of columns. Something like below
You can stack your data
And then you can plot it
