Reinaldo
How to create APA-format tables and plots from JMP data?
Hi JMP users,
I would like to know if there is an easy way to create/export tables and plots from JMP data to APA*-format.
Thank you!
* APA: American Psychological Association
~Rei
Re: How to create APA-format tables and plots from JMP data?
Can you give some examples of graphics that you are interested in? You can adjust a lot of the table and graph style elements in the preferences. Once you've got it set up you don't have to deal with it again.
M
Reinaldo
Hi @MikeD_Anderson, thank you for your reply.
I need to create those tables shown in https://cran.r-project.org/web/packages/apaTables/vignettes/apaTables.html using JMP.
I know there are a lot of table models, but what it is possible to create them easier than manually, it is great!
For example, I need to create that table manually extracting data from the Nonparametric Spearman's rho list (rather than correlation matrix) in the Analyse -> Multivariate Methods -> Multivariate because JMP provides a Nonparametric Spearman's rho comparison in a list-format rather than a matrix-format (e.g., Correlation and Covariance matrices).
Thank you.
~Rei
