geof:
Try adding a new column to your table that is type date/time and put your converted values there using a formula. Here is an example:
New Table( "Time Example",
Add Rows( 1 ),
New Column( "Column 2",
Character,
Nominal,
Set Values( {"2013-09-01-14:02:33:759000"} )
New Column( "Column 3",
Numeric,
Continuous,
Format( "yyyy-mm-ddThh:mm:ss", 19, 0 ),
Input Format( "yyyy-mm-ddThh:mm:ss", 0 ),
Formula(
Parse Date(
Substr( :Column 2, 1, 10 ) || "T" || Substr( :Column 2, 12, 8 ) ||
"." || Substr( :Column 2, 21 )
Michael Haslam
