jmpbeginner
using JSL to rename 'Oneway( )' output filename?
I have been using 'output table name( )' to rename all of my summary tables, but this does not seem to work for with oneway( :(
example:
dt_Oracle<<Oneway(
  Y( :Average ),
  X( :TOOL_ID ),
  Each Pair( 1 ),
  Box Plots( 1 ),
  Comparison Circles( 1 ),
  X Axis Proportional( 0 ),
  Grand Mean( 0 ),
  By( :Rec ),
  output table name("OneWay_"||tool||"_Average by Tool_ID_"||startDate||"_to_"||endDate||"_original"),
  Dispatch(
  "Oneway Plot",
  FrameBox,
  {DispatchSeg(
  Box Plot Seg( 1 ),
  {Box Style( "Outlier" ), Line Color( "Red" )}
  ), DispatchSeg(
  Box Plot Seg( 2 ),
I'm guessing it does not work since Oneway( ) is not a table?  is there any way to rename the oneway( ) report using JSL?
thanks!
ms
Super User (Alumni) ms
Re: using JSL to rename 'Oneway( )' output filename?
You can use << set window title.
Example:
obj = dt << Oneway( Y( :Height ), X( :Age ) );
obj << set window title( "test" );
ms
Example:
jmpbeginner
perfect! thank you!
