DELANDJ1985
How to convert character date column running APR-14 to JAN-22 into Quarterly (Q1,Q2,Q3,Q4) labels?
In the past I have substracted Month only string (JAN) from Jan-14 and then recoded individual months to new label (JAN) = (Q1). However this tack is very manual, is there a formula i can embed to automate this in the future?
Re: How to convert character date column running APR-14 to JAN-22 into Quarterly (Q1,Q2,Q3,Q4) labels?
Create new column and then add this as formula:
Local({month_list = (month_list = {"JAN", "FEB", "MAR", "APR", "MAY", "JUN", "JUL", "AUG", "SEP", "OCT", "NOV", "DEC"})},
			Ceiling(Contains(month_list, Word(1, :MonthYear, "-")) / 3)
Make sure you have correct column name in :MonthYear (in image below it is A)
If you have JMP16 you could first convert the character column to date column with format pattern and then use Quarter function
Column(dt, 1) << Set Name("MonthYear");
Column(dt, 1) << Data Type(Numeric,
	Format("Format Pattern", "<Mmm><-><YY>", 35),
	Input Format("Format Pattern", "<Mmm><-><YY>")
dt << New Column("Q", Numeric, Ordinal, Formula(Quarter(:MonthYear)));
If you don't have JMP16 you could do "conversion list" of months and then use that instead to get Quarters
Edit:
Formula for JMPs before 16 and no conversion to first column using list of months, contains(), word() and ceiling()
	Numeric,
	Ordinal,
	Formula(
DELANDJ1985
Appreciate the quick response - I'm on JMP 14 so do not have format pattern. I have added a sample file, could you perhaps show me how to use conversion list?
DELANDJ1985
Attempted to apply but perhaps i have input formula with basic error?
DELANDJ1985
Thanks Jarmo - the local variable feature is new to me but looks like it could be a game changer if i get the hang of it!
