Hi, I have a data table with discrete and numeric variables. The discrete variable is basically a serial identifier. The numeric variables are time series style: On of the variables is the time from start of data sampling, the other variables are properties the vary with time. In a typical plot prepared by graph builder, I create first a graph showing a continous variable versus time. Then I drag the serial identifier over the wrap tab in the graph layout. That splits the graphs according to the identifier. I want to be able to control the dimensions of the splitting process. Meaning that I want for instance always to have 4 sub graphs horizontally and as many sub graphs vertically depending on how many identifiers I have selected. I also want the horizontal dimension to be maintained when I apply filtering. Basically I want a behaviour similar to the use of templates and PROC GREPLAY in SAS Graph.
Yes, Graph Builder made a major leap forward in JMP 10. You may try to assign two dynamic "dummy" identifiers for Group X and Group Y, respectivele. One fixed four levels and the other varying according to total number of classes. However, it would never look exactly like a real graphbuilder wrap variable.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '6459' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '6459') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '6459') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
