KillerNO1314
How to configure the second Y axis when editing graph builder using script?
I want to use the histogram to display y(2)  as y(1), but only  Y1 had been displayed correctly ,how to write this script,anyone can help me?
Re: How to configure the second Y axis when editing graph builder using script?
The simplest way to do this is to build the graph interactively, and then under the red triangle, specify to have JMP save the script that will generate the chart as you have interactively built.
