ANLUN
How to compare paired data sets include the variation on the samples
Feeling i meeting the wall with comparing these two methods I'm testing.
I have 2 methods (1 and 2) both analysed on the same sample. For both methods triplicates have been measured for each sample. So now I want to compare method 1 vs 2 including the know variation to see if statistically significant?
Re: How to compare paired data sets include the variation on the samples
What is this study, an analytical method comparison? An equivalence study for instrument replacement? Is one of the methods a reference? What do you mean by, "So now I want to compare method 1 vs 2 including the know variation to see if statistically significant?"
Your data is pre-summarized, so you you could use Bivariate platform with the mean and then select Fit Orthogonal to compare the null hypothesis of an intercept = 0 and a slope = 1. You could use Matched Pairs platform if you are looking for a difference in the mean.
I would recommend that you include the individual replicate measurements instead of summarizing the data into the mean and standard deviation. You could use a Fit Least Squares after stacking the measurement columns. The measurement in the Y role and then enter Sample as a random effect.
Hard to say much more given we know practically nothing about your study, your intentions, or your needs.
ron_horne
Hi @ANLUN
if you are looking for inspiration from the variety of options for method comparison try this add in: Method Comparison
Otherwise, we would need to know much more before being able to help.
