jasongao
How to combine two columns (with missing data)?
got a table with missing data like this:
Column1Column2
1•
•5
•7
3•
Need to combine it it to one column
Column3
1
5
7
3
I used sum but it didn't work. The only way I can do is using If and is Missing() formual. Any fast way to combine it?
Thanks!
jasongao
Re: How to combine two columns (with missing data)?
OK. I figured out. I need to use sum() instead of +.
