SDF1
Help understanding how Lift curves are calculated
Dear JMPers,
  (computer details: I have JMP Pro 14 on a W7 Enterprise, 64-bit computer.)
  I am trying to better understand how JMP actually calculates a Lift curve. I understand conceptually the ROC and Lift curves, but I'm having a hard time calculating a Lift curve myself. The JMP help/support page (https://www.jmp.com/support/help/14-2/lift-curve.shtml#1276958) isn't all that helpful in understanding how it takes the probability column from your prediction and turning it into a Lift curve. I have a table where I've sorted it according to the probability that the outcome is True based on my model, and want to now calculate "by hand" (i.e. using a column formula or multiple columns) the Lift curve. It would be great to actually see an example.
  Any help on this is much appreciated.
Thanks!,
DS
0 REPLIES 0
