UserID16644
Level V
How to combine multiple plots in 1 tab using JSL
Hi, I have two different plots and I would like to combine them in one tab on my journal.
dt=open("$SAMPLE_DATA/big class.jmp");
// Plot 1
biv = dt << Bivariate( invisible, Y( :height ), X( :weight ), By( :sex ) );
// Create the window, with the first tab
nw=New Window("Tabs", text box("here are the tabs"), tb = Tab Box((report(biv[1])[outlinebox(1)])<<get title ,report(biv[1])));
//Plot 2
biv2 = bivariate( x( :height ), y( :weight ), invisible );
tb << Append( "Plot 2", biv2 << Report); //what I currently do
My question is, how can I combine these two different plot in 1 tab? I am using JMP 15
Re: How to combine multiple plots in 1 tab using JSL
Try the below JSL, it is one way to do what you want
// Plot 1
dis = Distribution( Continuous Distribution( invisible, Column( :height ) ) );
nw = New Window( "Tabs",
	Text Box( "here are the tabs" ),
	tb = Tab Box( (Report( biv[1] )[Outline Box( 1 )]) << get title, Report( biv[1] ) )
//Plot 2
tb << Append( "Plot 2", hlb = H List Box( biv2 << Report ) ); // Add an H List Box to the tab
hlb << append( dis << report );  // Append additional items to the H List Box
// Plot 1
//Plot 2
