CrownofTears
Do you know why my script fully runs when I run it manually but it does not work when I run it from a command in the toolbar?
Hi Guys,
I have this script that works 100% when I run it manually.
When I run it from the toolbar(automatically) it does not run the last section.
Do you have an idea of why this is happening?
I added a comment in the script in the point is not working anymore:
//STARTING FROM HERE THE SCRIPT DOES NOT RUN IN TOOLBAR MODE
//Script for GRR Anlaysis for Qual Data
names = {};
//prueba={};
RepeatabilityData = {};
ReproducibilityData = {};
GaugeRRData = {};
ParttoPartData = {};
NDCData = {};
Datos_table = Current Data Table();
For( i = 1, i <= N Col(), i++,
	Insert Into( names, Column Name( i ) )
dlg1 = Dialog(
	Title( "GR&R" ),
	"Select Tests",
	vlist( selectiontests = List Box( names ) ),
	"Select Channel Column",
	vlist( selectionchannel = List Box( names ) ),
	"Select Category (Pre/Post) Column",
	vlist( selectioncategory = List Box( names ) ),
	"select Devices Number Column",
	vlist( selectionSN = List Box( names ) ),
	synch = Check Box( "Generate Journal", 0 ),
	hlist( button( "OK" ), button( "Cancel" ) )
if (dlg1["Button"]==1,
	column(dlg1["selectionchannel"])<<set modeling type("Nominal");
	column(dlg1["selectioncategory"])<<set modeling type("Nominal");
	column(dlg1["selectionSN"])<<set modeling type("Nominal");
	Report= New Window("GRR Report",
	For(i=1, i<=Nitems(dlg1["selectiontests"]),i++,
		uno=Variability Chart(
			Y(dlg1 ["selectiontests"][i]),
			X(dlg1 ["selectionchannel"], dlg1["selectionSN"]),
			Model (Crossed),
			Historical Sigma (0),
			Connect Cell Means (1),
			Show Group Means (1),
			Show Grand Mean (0),
			Show Grand Median (1),
			XBar Control Limits (0),
			S control Limits (1),
			Std Dev Chart (0),
			Mean Plots (0),
			Mean of Std Dev (1),
			//Gauge RR (10,2),
			//Gauge RR Report (0),
			//Journal Window;
		dos=Variability Chart(
		X(dlg1 ["selectioncategory"], dlg1["selectionSN"]),
		Model (Crossed),
		Variability Chart( 0 ),
		Std Dev Chart (0),
		Mean Plots (1),
		report(uno)[framebox(1)]<<frame size(978,150);
		uno<<Show Grand Mean(1);
		uno<<XBar Control Limits(1);
		report(dos)[framebox(1)]<<frame size(186,150);
		report(dos)[framebox(2)]<<frame size(300,150);
		report(dos)[framebox(3)]<<frame size(300,150);
//GRR Analysis Data Table
TabWin=Datos_table << Tabulate(
	Add Table(
		Column Table(
			Analysis Columns(
			Grouping Columns(dlg1 ["selectioncategory"] ),
			Statistics( Mean )
		Row Table( Grouping Columns( :SN, Chan ) )
TabData = TabWin<< Make Into Data Table;
TabWin << Close Window;
TabData <<set name("GRR Analysis");
//Section for Deltas in GRR analysis
CurrentDataTable(TabData);
ColNum=NCols();
For (j=3, j<=ColNum, j=j+2,
	ColLen=Length(Char(Column name (j)));
	ColName=Left (Char(Column Name(j)),ColLen -5);
	NewCol=Substr(ColName,6);
TabData<<New Column(
		"Delta: "||NewCol,
		Numeric,
		Formula(
			(As Column((j))-As Column((j+1)))/As Column(j)
		Format("Percent",5,2)
ColDelta=(ColNum-2)/2;
ColStart=4;
ListDelta = {};
For(k=1, k<=ColDelta, k++,
	Insert Into(ListDelta, Column Name (Eval(ColNum+k)));
	TabData << Move Selected Columns(
		{Column (ColNum+k)}, after(Column(ColStart))
	ColStart=ColStart+3;
//Delta Variability
	DeltaVar= New Window("GRR Delta Report",
		For(l=1, l<=Nitems(ListDelta),l++,
			//Col Std Dev(As Column(ListDelta[12]));
			if(Col Std Dev(As Column(ListDelta[l]))>0.4,
				ListDelta[l]<<set property ("Spec Limits",{LSL(-1 ), USL(1),Show Limits( 1 )})
			if(Col Std Dev(As Column(ListDelta[l]))<0.4,
				ListDelta[l]<<set property ("Spec Limits",{LSL(-0.1 ), USL( 0.1),Show Limits( 1 )})
			if(Col Std Dev(As Column(ListDelta[l]))<0.001,
				ListDelta[l]<<set property ("Spec Limits",{LSL(-0.01 ), USL( 0.01),Show Limits( 1 )})
			tres=Variability Chart(
				Y(ListDelta[l]),
				X(:Chan, :SN),
				Model (Crossed),
				XBar Control Limits (1),
				Std Dev Chart (0),
				Mean Plots (0),
				//Gauge RR (10,2),
			//report(tres)[FrameBox(1)]<<frame size(978,150);
			//tres<<Show Grand Mean(1);
			//tres<<XBar Control Limits(1);
Craige_Hales
Re: Do you know why my script fully runs when I run it manually but it does not work when I run it from a command in the toolbar?
@CrownofTears -- way too late, I suppose, but try adding
TabData << RunFormulas;
in place of the comment. JMP's column formulas run when JMP is idle, so running it a section at a time will allow the formulas to evaluate. Adding wait statements might let the formulas have enough idle time to complete, but it is impossible to pick the perfect wait time. <<RunFormulas is fast. Usually JMP can figure out when it needs to force the formulas to finish running; My guess is that
is not figuring it out.
Craige
ron_horne
Hi @CrownofTears ,
when i had these issues in the past i found out that adding Wait (0.1) before the loop and at the end of each loop made it work. in your case i a do not have an obvious suspect for the slow behaviour. i would just put a Wait (0.1) after each ; in the last loop and see if it works
this solves the issue that sometimes jmp moves on the the next step without making sure the previous has ended.
Craige_Hales
Craige
CrownofTears
Hi @Craige_Hales, we shoud exactly add the
After this comment?
if yes, already did and did not work :(
Craige_Hales
(Yes, that was what I meant.)
I'm guessing.
Are you getting messages in the log window when it fails? You might add print() statements to isolate the failure.
My next guess is the current data table() isn't doing what you expect. Try using explicit data table scoping instead of depending on CurrentDataTable.
Depending on the CurrentDataTable is a fragile way to build code because
  • it can change when another table becomes current (which seems likely with a new window opening)
  • it can be different in different contexts (which seems likely with a toolbar context in play)
Another thing to try: uncheck the "use here namespace" in the toolbar to see if it works. That will tell us something too.
Craige
