bernie426
How to color/marker selected rows based on multiple selection criteria?
I am writing a script that is able to color and mark selected rows. Let's take the Big Class table as an example.
The following is my script, can anyone help out to get the selected rows to be colored to specific color like "Blue" and able add different marker for age =12 and age=13.
Open( "$SAMPLE_DATA/Big Class.jmp" );
  For Each Row( Selected(Row State()) = And ( Or (age == 13, age ==12), sex =="M"))= Color State( {0, 0, 225} );
  Color To RGB( Color Of( Selected( Row State() ) ));
Many Thanks,
Kevin_Anderson
Re: How to color/marker selected rows based on multiple selection criteria?
Hi, bernie426!
There's a bunch of ways to do this.  Here's one:
BigClass_dt = Open( "$SAMPLE_DATA/Big Class.jmp" );
BigClass_dt << Select Where( And ( Or (age == 13, age ==12), sex =="M")) << Colors(RGB Color(0,0.333,0.667)) << Markers( "\!U2642" ) << Clear Select;
BigClass_dt << Select Where( And ( Or (age == 13, age ==12), sex =="F")) << Colors(RGB Color(0.376,0.248,0.376)) << Markers( "\!U2640" ) << Clear Select;
If you had many color and marker assignments to do, you might want to be a little less explicit.
Kevin_Anderson
Hi, bernie426!
bernie426
Thanks, Kevin. It worked out great for me.
Many Thanks,
