Hi All,
Is there a way to just color the column header by using JSL?
As an example, I want to color column header for name, age, sex, height, weight only, not coloring the cells.
I believe Jim is correct. This feature is not supported, but there is a JMP Wish List Item open for voting here:
Set background color in column header/column names
~John
it's available now with Jmp18 :)
