miguello
How to check if "Create Database Connection" is successful?
Many of my scripts connect to a DB as soon as they are started. DB is in intranet, so users need to:
1. Be connected to internal network OR have VPN on
2. Have ODBC source set up correctly
Sometimes they don't.
I want to warn users that the DB is not available instead of script erroring on them. What would be a correct way of checking if "Create Database Connection" was successful and returned a valid handle?
Thanks,
M.
miguello
Re: How to check if "Create Database Connection" is successful?
Is Scriptable(dbc);
works just fine, anybody has a code snippet with modal window that would just close the whole AddIn in case it evaluates "0"?
Thanks,
M.
pmroz
You could try logic like this:
my_dbc = create database connection("foobar");
if (isempty(my_dbc) | is missing(my_dbc),
	_nw = new window("Create DBC: Empty Value", << modal,
		textbox("Error: The database connection is empty."),
		throw("Empty database connection string");
