  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
sofiasousa24
How to change the variables name in PCA loading scatter plot?
I'm trying to change the variables name in loading scatter plot but I can't. The variables included in PCA analysis are from two linked data tables. I'd like to change the columns name to new abbreviation names.
Thank you very much in advance.
Re: How to change the variables name in PCA loading scatter plot?
The names of the variables in the loadings plot are the names of the data columns. Change the column names before the PCA.
ih
Super User (Alumni) ih
If for whatever reason you don't want to rename the columns, you could make calculated columns when launching the platform.  Here is one table with a PCA showing the original names and one with shorter names:
dt = Open( "$Sample_data/Quality Control/Chemical Reactor Process.jmp" );
New window("PCA Compare",
	h list box(
		dt << Principal Components(
			Y( :A.Feed.S1, :D.Feed.S2, :E.Feed.S3, :Total.Feed.S4 ),
			Estimation Method( "Row-wise" ),
			Standardize( "Standardized" ),
			Loading Plot( 2 )
			Transform Column( "S1", Formula( :A.Feed.S1 ) ),
			Transform Column( "S2", Formula( :D.Feed.S2 ) ),
			Transform Column( "S3", Formula( :E.Feed.S3 ) ),
			Transform Column( "S4", Formula( :Total.Feed.S4 ) ),
			Y( :S1, :S2, :S3, :S4 ),
			Loading Plot( 2 )
