yetebreo
How to change row legend colors using JSL
Hi I am currently working on a script but I am stuck with one requirement that is to put specific colors for a specific row legend.
For example I have:
LEGENDNAME_OO
LEGENDNAME_PP
LEGENDNAME_QQ
I want to color legend with _OO suffix with red _PP with blue and _QQ with green
Thanks
uday_guntupalli
Level VIII
Re: How to change row legend colors using JSL
Hello ,
dt << Color by Column( :Age );
Wait( 2 );
dt << Color Rows by Row State;
I think you can further customize this  to match your needs
Best
uday
Best
Uday
6 REPLIES 6
It's depend of graph you are using.
For Overlay Plot, you can add Connect Color option to define colors options.
Overlay Plot(
  Y( :AA, :BB, :CC ),
  Connect Thru Missing( 1 ),
  :AA(
  Connect Color( 38 ),
  Line Width( "Thin" )
  :BB(
  Connect Color( 54 ),
  :CC( Connect Color( 71 ),
      Line Width( "Thin" ) ));
Guillaume
uday_guntupalli
Level VIII
Hello ,
Wait( 2 );
Best
uday
Best
Uday
yetebreo
Here is the code I am using
open("C:\Users\krash_tpd_cnt_char.csv");
Bivariate(
    Y(  :VALUE ),
    X(  :TEMP  ),
    By(  :VCC  ),
        Dispatch({},"1",ScaleBox,{
            ,Show Major Grid( 1 )
        Dispatch({},"2",ScaleBox,{
        Dispatch( {}, "Bivar Plot", FrameBox,
            {Row Legend(
                WAFER ,
                Color( 1 ),
                Color Theme( "JMP Default" )
this is what is being generated
but i want *-TT to be green, FF to be red then SS as is (blue)
Try changing the value ordering in the source column so that FF is first and -TT is second. I realize this is not a JSL solution, but it may get you where you want to be.
yetebreo
I am not sure how to change the ordering since these names could be anything only that it ends with TT FF and SS.
I hop somebody can help
You can do a script similar to this one to order value.
This script is not "perfect" but seems to be okay
dt = CurrentDataTable();
col = Column("VCC");
list = {};
ulist = {};
listTT = {};
listSS = {};
listFF = {};
/* Add data from VCC into a list */
For (i=1, i<=Nrows(dt),i++,
     InsertInto (list,col)
/* Create a unique list */
For (i=1,i<=Nitems(list),i++,
  If (Nrows(Loc(ulist,list)) == 0,
  InsertInto (ulist,list)
/* Create 3 lists contains pattern */
For (i=1,i<=Nitems(ulist),i++,
    if (contains(ulist,"TT") > 0,
    InsertInto (listTT,ulist)
    if (contains(ulist,"SS") > 0,
    InsertInto (listSS,ulist)
    if (contains(ulist,"FF") > 0,
    InsertInto (listFF,ulist)
/* Create the final list to have color order*/
list = {};
InsertInto(list,listFF);
InsertInto(list,listTT);
InsertInto(list,listSS);
/* Put Value ordering property */
col << Set Property("Value Ordering",list);
/* Then make your analysis */
Guillaume
