Dorami
How to change multiple columns attributes using scripts?
I have a table with col name : Name, Sex, Track 1, Track 1, Track 3, Track 4, Track 5 .... Track 50
All cols are character, nominal. I would like to change Track 1 to Track 50 to number, continuous. How can I do that using script?
Re: How to change multiple columns attributes using scripts?
Easiest way is to select all columns and use Standardize Attributes
and then copy the captured script
Other option would be to use << Get Column Names("String") to get list of column names and then loop over that list while using << Data Type("Numeric") and << Modeling Type("Continuous").
