natalie_
Level V
How to change file names?
Hi everyone,
Earlier I asked about how to extract files and it is working great!  Now I want to use these files, but the files are saved with ".pda-iv" (the file are coming from a parameter analyzer B1506).  In my script to open the file (ronFolder = Open(directory || deviceName || "\" || "RDS-ID.pda-iv");), I get an "Error with File: Path is Invalid" error.
Is there a way to change the name of the file?  For example, instead of RDS-ID.pda-iv, have it as RDS-ID.text.
Here is my code from how I extracted files:
/* 1) This script assumes all files within zipped files are text files.
   2) Make sure only zipped files are in the directory (ie., only B1506A data sheet zipped files)*/
directory = Pick Directory ();  //Choose directory where zipped folders are
filesInDirectory = Files In Directory(directory); //get list of files in directory
nFiles = N Items(filesInDirectory);  //get number of zip files in directory
For(i=1, i<=nFiles, i++,
      fileName = filesInDirectory[i];  //select ith file in list of
      /********Determine Device Name***********/
      pos = Contains(fileName, "_");      ///(example file name: GS66508T 65R6 #1_7-19-2016_11-04-28_AM.pda-ds)
      deviceName = left(fileName,pos-1);
      /*******Create subdirectory for extracted files.
            Make sure it is in a directory separate from all the zipped files*****/
      subDir = "C:\R&D Data\TSMC\E-HEMT\GS66508T\GS66508T 65R6 extractions\" || deviceName || "\";
      Create Directory(subDir);
      za = Open(directory || fileName, zip); //Open zipped folder
      dirlist = za << dir;                            //Get list of files in zipped folder
      nZippedFiles = N Items(dirlist);          //get number of files in dirlist
      /*Step through dirlist and save each text file into the new sub directory*/
      for(k=1, k<=nZippedFiles , k++,
            If(Right(dirlist[k],4) == ".txt",
                  text = za << read (dirlist[k]);
                  Save Text File(subDir || dirlist[k], text),);
natalie_
Level V
Re: How to change file names?
Got it!  It was really simple.  I am not sure why I got hung up on the Save Text File function.
  fileName = filesInDirectory;  //select ith file in list of
  subDir = "C:\R&D Data\TSMC\E-HEMT\GS66508T\GS66508T 65RG new extensions\" || deviceName || "\";
  If(Right(dirlist,4) == ".txt",
  text = za << read (dirlist);
  fileNameZip = dirlist;
  pos = Contains(fileNameZip, ".");
  newFileName = Left(fileNameZip, pos-1);
  newFileName = newFileName || ".txt";
  Save Text File(subDir || newFileName, text),);
natalie_
Level V
Strange, I can open them manually but I can't get the script to work?
natalie_
Level V
