LeahFlumerfelt
How to change default graph image export background color from the gray to something else?
How do you change the default setting for image background color when copying graphs out of JMP?
Whenever I hit s, copy the graph, and paste it into a different program, the background color is light gray. I want it to be white. Thank you!
Victor_G
Re: How to change default graph image export background color from the gray to something else?
Hi @LeahFlumerfelt,
Welcome in the Community !
You can change your preferences regarding the default option of the platforms and graphs. To do this, go into "File", "Preferences", and then check the panel tab "Style". You should find options for the graph background colors :
Hope this answer will help you !
Victor GUILLER
LeahFlumerfelt
P.S. And I want to change this setting permanently
Victor_G
Hi @LeahFlumerfelt,
Victor GUILLER
LeahFlumerfelt
Excellent! Thank you so much.
