helalmob
How to calculate row percentage for dimension subtotal?
I have the following data with 20+ measures. Raw data shown here is a sample with only one measure. With Tabulate I can get subtotal for each site for all levels of Var2 (0,1,2,3) and level of Var1 (A, B). For example, the subtotal for Site1=461 (438+19+2+2). I am comparing the percentage of measure for each level of Var2 between the level of Var1 for each Site. Table1 presents subtotal for each site for each level of Var2 and Var1. Table 2 shows the percentage of the total for each level of Var2 and Var1. This is the desired percentage that I like to compare and contrast. In this example (Table 2), there is not much variability between A & B (Var1 level) across each level of Var2 (0,1,2,3) for each site. However, I need to perform similar comparisons across 20+ measures. I appreciate any guidance/help to calculate the percentages.
Raw Data
Site
Var1
Var2
Measure
Site1
A
0
438
Site1
A
1
19
Site1
A
2
2
Site1
A
3
2
Site2
A
0
321
Site2
A
1
0
Site2
A
2
0
Site2
A
3
0
Site1
B
0
57
Site1
B
1
4
Site1
B
2
0
Site1
B
3
0
Site2
B
0
37
Site2
B
1
1
Site2
B
2
0
Site2
B
3
0
Table 1
Site1
Site2
Var2
Var2
0
1
2
3
0
1
2
3
Var1
N
N
N
N
Total
N
N
N
N
Total
A
438
19
2
2
461
321
0
0
0
321
B
57
4
0
0
61
37
1
0
0
38
All
495
23
2
2
522
358
1
0
0
359
Site1
Site2
Var2
Var2
0
1
2
3
0
1
2
3
Var1
Total
Total
A
95%
4%
0%
0%
100%
100%
0%
0%
0%
100%
B
93%
7%
0%
0%
100%
97%
3%
0%
0%
100%
All
95%
4%
0%
0%
100%
100%
0%
0%
0%
100%
Thank you,
Helal
Phil_Kay
Re: How to calculate row percentage for dimension subtotal?
I think this is what you want?
I have attached your example data with the Tabulate script. Hopefully you can see how I used Tabulate from this.
By the way, it is good to attach your example data as a .jmp file to your JMP Community post - it makes it easier for the community to help you.
I hope this helps,
Phil
Phil_Kay
Personally, I prefer a graphical analysis. You could use Graph Builder for this kind of comparison:
