PhamBao
How to calculate UCL from Mahalanobis Distance
Hi all,
Currently, I am using JMP 12 version
Do you know how to calculate UCL distance from Mahalanobis Distance chart?
If you guy know how to get it, could you please show me the formula?
Sincerely
11 REPLIES 11
Re: How to calculate UCL from Mahalanobis Distance
Click the "?" from JMP toolbar and then click on Mahalanobis Distances, this will open Help page Outlier Analysis . From here you can find Mahalanobis Distance and find its documentation Mahalanobis Distance Measures and finally
PhamBao
Hi Jthi,
got it -- I already find the document due to your instruction.
However, do you know whether we can get syntax / code to calculate UCL
Thanks
This example illustrates how to calculate UCL with JSL.
Names Default to Here( 1 );
alpha = 0.05;	// typical decision level for type I error risk
n = 1600;		// about the number in your plot
p = 5; 			// guess of the number of variables used to compute distance
ucl = Sqrt( (((n-1)^2)/n) * Beta Distribution( 1-alpha, p/2, (n-p-1)/2 ) );
PhamBao
Thank for your instruction
I try to follow your instruction but the result is not correct.
I will display the script below and image
Based on your instruction, does p =2 and n = 85
Multivariate(
	Y(:DELTAMINIZ, :CARRIER_X),
	Estimation Method("Row-wise"),
	Matrix Format("Square"),
	Scatterplot Matrix(Density Ellipses(1), Shaded Ellipses(0), Ellipse Color(3)),
	Jackknife Distances(1)
What is the UCL shown if you click the red triangle next to Multivariate and select Outlier Analysis > Mahalanobis Distance?
My apologies! I used the wrong function. I also added the calculation of the jack-knife UCL. Please use this modified script instead of the one that I posted earlier.
n = 31;		// about the number in your plot
p = 7; 			// guess of the number of variables used to compute distance
m ucl = Sqrt( (((n-1)^2)/n) * Beta Quantile( 1-alpha, p/2, (n-p-1)/2 ) );
j ucl = Sqrt( (((n-2)*(n^2))/((n-1)^3))*((m ucl^2)/(1-((n*(m ucl^2))/((n-1)^2)))) );
Show( m ucl, j ucl );
PhamBao
It works like a gem. Appreciate !
PhamBao
Hi Mark_Bailey,
I use Jackknife method to detect outlier, but I found 1 case that I really need your advice.
You can refer to the images below.
Based on the right chart, all the data points on 8th carrier_x should be outliers. However, when I use Jackknife method with default settings, this method only points out 1 outlier instead 4.
I believe that not enough data points leads to the result
Do you have any suggestion / method that I can catch outliers more efficiently?
PhamBao
Appreciate Jthi for your recommendation
