uday_guntupalli
Level VIII
How to build a dynamic JSON object
All,
    I am wondering how to build a dynamic JSON object in JSL ?
request = New HTTP Request(
	url( "http://httpbin.org/post" ),
	Method( "POST" ),
	JSON( "\[{"username":"bob","address":"12345"}]\" )
   Using the example from the scripting index, if I wantedt to vary the username from bob to say mark and address from 12345 to 12346 and I have 10 such calls, I would prefer building that as a dynamic object outside. I initially ventured down the path of building it as an Associative Array and then using the As JSON Expr() , however, that is resulting in an error. My approach in that case was:
MyAA = Associative Array();
MyAA["username"] = "bob" ;
MyAA["address"] = "12345" ;
request = New HTTP Request( url( "http://httpbin.org/post" ), Method( "POST" ), JSON( As Json Expr(MyAA)) );
Of course, this is not happening for this example, but the api I am trying to call on. However, when I pass hardcoded JSON as an input, the api call works as expected.
Any help is appreciated.
Best
Uday
16 REPLIES 16
uday_guntupalli
Level VIII
Re: How to build a dynamic JSON object
@nascif_jmp  and @bryan_boone ,
        Thank you for your responses. Your responses helped me get somewhere, however I have a couple of questions:
1. Can you kindly provide an example of accepted JSON array format in JSL ? Is this accepted ?
2. Does the scripting index or scripting guide cover the portions on JSON array or how to define an empty JSON object as nasicf has kindly shown ?
   a. If yes, I would like to read that
   b. If no, I would request that this be added to the documentation, because I couldn't find it anywhere
Best
Uday
Do you have the link to the API. I don't think you've listed valid JSON.
At least the JSON Editor in Chrome doesn't think so.
Thanks
Ah.
I had a transcribing error going from picture to text.
If I rewrite it like this using the chrome add in JSON Editor, I see a List of Associative Arrays
    "month": 1,
    "month_name": "Jan",
    "albedo": 0.2,
    "soiling_loss": 2
    "month": 2,
    "month_name": "Feb",
    "albedo": 0.2,
    "soiling_loss": 2
    "month": 3,
    "month_name": "Mar",
    "albedo": 0.2,
    "soiling_loss": 2
    "month": 4,
    "month_name": "Apr",
    "albedo": 0.2,
    "soiling_loss": 2
    "month": 5,
    "month_name": "May",
    "albedo": 0.2,
    "soiling_loss": 2
    "month": 6,
    "month_name": "Jun",
    "albedo": 0.2,
    "soiling_loss": 2
    "month": 7,
    "month_name": "Jul",
    "albedo": 0.2,
    "soiling_loss": 2
    "month": 8,
    "month_name": "Aug",
    "albedo": 0.2,
    "soiling_loss": 2
    "month": 9,
    "month_name": "Sep",
    "albedo": 0.2,
    "soiling_loss": 2
    "month": 10,
    "month_name": "Oct",
    "albedo": 0.2,
    "soiling_loss": 2
    "month": 11,
    "month_name": "Nov",
    "albedo": 0.2,
    "soiling_loss": 2
    "month": 12,
    "month_name": "Dec",
    "albedo": 0.2,
    "soiling_loss": 2
nascif_jmp
This seems to work.
innerList = {};
InsertInto(innerList, [ "month" => 1, "month_name" => "Jan", "albedo" => 0.2, "soiling_loss" => 2.0]);
InsertInto(innerList, [ "month" => 2, "month_name" => "Feb", "albedo" => 0.2, "soiling_loss" => 2.0]);
InsertInto(innerList, [ "month" => 3, "month_name" => "Mar", "albedo" => 0.2, "soiling_loss" => 2.0]);
monthlyFactors = {innerList};
je = As JSON Expr(EvalList(monthlyFactors));
Show(je);
I think the real issue is knowing the right API calls to the JSL list and associative arrays data structures, and their behavior as far as evaluating variables, returning a copy vs a live reference, and so on. The fact that they are being used to build a JSON object is incidental.
Having said that, with the new support for REST APIs from JMP I agree that having a session with a more detailed, end-to-end example would be helpful. I will pass this sugestion alone to our doc team. Thanks for the suggestion!
And don't forget you can create JSON by just concatenating strings in the JSON format.
No Lists or Associative Arrays needed.
nascif_jmp
That was for building it step by step, the complete "hardcoded" version would be just
monthlyFactors = { {
[ "month" => 1, "month_name" => "Jan", "albedo" => 0.2, "soiling_loss" => 2.0],
[ "month" => 2, "month_name" => "Feb", "albedo" => 0.2, "soiling_loss" => 2.0],
je = As JSON Expr(monthlyFactors);
Show(je);
As a rule of thumb:
* JSON arrays map to JSL lists (not matrices or vectors, beware of the '[]' similarity);
* JSON dictionaries map to JSL associative arrays;
* Check for non-evaluated variable references;
* Check if data structure modifying calls actually change the target object (as opposed to returning a modified copy).
