toadpalmer
Help me find standard errors for least square means estimates in Repeated Measures?
Hi all,
Does anyone know how to find the standard errors for least square means estimates from a repeated measures analysis in JMP Pro 14? I have 2 x 2 design, which is re-sampled over time, and the output tables provide least square means for each factor combination at each time, but no standard errors for those estimates. Is it possible to also find the standard errors somehow?
Thanks for any help!
Re: Help me find standard errors for least square means estimates in Repeated Measures?
Please see this note from Technical Support: analysis of a repeated measures experiment.
I followed the example for the split-plot study. The results include the estimates and their standard errors:
Is this result what you are looking for?
toadpalmer
I think that should do it, thanks much Mark!
