Thomas1
Level V
How to avoid JMP Alert window in a JSL
If( N Table() == 0, Open(), );
dt = Current Data Table();
//Create Lauch Window for prompting dialog
nw = New Window( <<Modal,
    V List Box(
        Lineup Box( N Col( 2 ), Spacing( 14 ), ),
        H List Box(
            Panel Box( "Select Columns", clb = Filter Col Selector( dt, all ) ),
            Panel Box( "Cast Selected Columns into Fit Model Roles",
                    Button Box( "Y, Response", clbY << Append( clb << Get Selected ) ),
                    clbY = Col List Box( "Numeric", MinItems( 1 ), nlines( 8 ) ),
                    Button Box( "X, Two Samples",
                        clbXs << Append( clb << Get Selected )
                    clbXs = Col List Box(
                        "Character",
                        MinItems( 1 ),
                        MaxItems( 1 ),
                        nlines( 1 )
            Panel Box( "Action",
                Button Box( "OK",
                    yVars = clby << Get Items( "Column Reference" );
                    eVars = clbXs << Get Items( "Column Reference" );
                Button Box( "Cancel" ),
                Text Box(),
                Button Box( "Remove",
                    clbY << Remove Selected;
                    clbXs << Remove Selected;
        H List Box()
If( nw["button"] == -1,
    Throw( "Cancelled!" )
Re: How to avoid JMP Alert window in a JSL
If( N Table() == 0,
	Clear Symbols( dt );
	Try( dt = Open() );
	If( Is Empty( dt ), throw());
Open will throw an error if Cancel is pressed and you can catch it with Try-catch.
Try(
	dt = Open();
	show(exception_msg);
Do error handling in the catch part, example above will just print the message to log and lets script to continue running.
Thomas1
Level V
Thanks for your fast reply. What additional code must be added or changed after the open dialog is canceled (with no alert window) to stop the code from running the dialog window?
If( N Table() == 0,
	Try( dt = Open() );
Thomas1
Level V
Thanks, Jim. That was exactly what I was looking for.
