Dyan
How to automatically select table in journal in order to rerun in new window
Hi JMP Community,
After generating a Journal, I would use "rerun in new window" to rerun the plot, however before it executes it will ask to me select a table. How do i make it so that it will automatically select the tables in the folders for me since the both are in the same folder.
Thank You.
Re: How to automatically select table in journal in order to rerun in new window
I'm not sure if it can be done through a journal as it seems like Journal doesn't save the data table reference (reports in Journal are also static). I haven't really used Journals so only option that quickly comes to my mind is to to add a button which would then run a script to re-create the report (also if you have JMP17 using Workflow builder might work)
Dyan
Thanks for the suggestion to making a button. I went ahead and make a button that connects to a script that opens my data tables.
Byron_JMP
The second option is the key to making this work the way you want.
Choose the Edit Script option
Screen Shot 2023-03-15 at 6.53.00 AM.pngScreen Shot 2023-03-15 at 6.53.00 AM.png
 Then edit the script like this:
Screen Shot 2023-03-15 at 6.53.10 AM.pngScreen Shot 2023-03-15 at 6.53.10 AM.png
 The first line tells JMP which file to open. Then on the second line insert "dt<<" before the first argument. That sends the argument to the specified data table.  Note that "dt" is an arbitrary variable name.
Hope this helps
-B
